Solve Calc Problem: Find y if dy/dt=ky and k is a Nonzero Constant
  • Thread starter Thread starter radtad
To solve the differential equation dy/dt = ky, where k is a nonzero constant, the general solution involves integrating to find y = Ce^(kt), where C is the constant of integration. The user initially believed the answer was b (2e^(kt)), but realized they overlooked the constant of integration. The correct form includes a constant, which can be represented as C1, leading to multiple valid solutions depending on initial conditions. A typo in the answer choices was also acknowledged, confirming that choice c should be e^(kt) + 3. Understanding the role of the constant of integration is crucial for identifying the correct solution.
radtad
We have a set of problems for hw. I am stuck on 1 where I know the answer but can't seem to get it.
If dy/dt=ky and k is a nonzero constant then y could be
a. 2e^kty b. 2e^kt c. e^kt d. kty+5 e. 1/2ky^2 +1/2
I know the answer is b but i can't get that answer
Here is my work
S=integral sign
dy/dt=ky
dy/y=kdt
Sdy/y=kSdt
lny=kt
e^lny=e^kt
y=e^kt
How do u get a 2 in there for choice b
You forgot about the constant of integration:
\frac{dy}{dt}=ky
\frac{dy}y=kdt
\int{\frac{dy}y} = \int{kdt}
\ln y = kt +C
e^{\ln y} = e^{kt + C}
y = e^{kt}\cdot e^C
eC is also a constant, so it can be written as C1 if you like.The value of C1 will depend on the initial conditions. Unless there's a typo in your answer list, I can see two answers that are of this form:
b. y=2e^{kt}
and c. y = e^{kt}
I hope that helps.
thanks forgot the C and yea choice c was a typo it should be e^kt +3
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
