Diameter of Graphs: Why 2 & Exceptions
  • Thread starter Thread starter Stephane G
    Diameter Graphs
The diameter of the complement of a tree is typically 2 because the maximum distance between any two vertices in the complement is minimized by the tree's structure. In a tree, any two vertices are connected by a unique path, and adding edges in the complement connects distant vertices directly. Exceptions occur in specific configurations, such as when the tree is a star or has a high degree of connectivity, which can lead to a larger diameter. Understanding these exceptions requires analyzing the specific structure of the tree and its complement. Overall, the general rule holds true for most tree complements, with notable exceptions based on their topology.
Stephane G
Explain why the diameter of almost every complement of a tree will be 2 and find all exceptions to this rule
Mathematics news on Phys.org
No.
If this is a homework problem, you need to post it in the homework section. Either way, you need to explain what it is that's giving you trouble, and show us what you've done so far.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
