How Does Gate Resistance Rg Impact JFET Amplifier Performance?
  • Thread starter Thread starter chunhui219
    Gate Resistor
Gate resistance, Rg, is essential in JFET amplifier circuits as it determines input impedance and facilitates proper biasing. It acts as a pull-down resistor, allowing the coupling capacitor to charge and discharge effectively without signal loss. The value of Rg should be significantly larger than the capacitor's reactance at the lowest frequency of interest to ensure signal integrity. Calculating Rg involves considering the desired input impedance and using the formula Rg = (Vgs / Idss) * (1 - gm * Rl). Properly configured, Rg stabilizes the amplifier and enhances performance by matching input impedance and minimizing distortion.
chunhui219
How to calculate gate resistance, Rg in the JFET amplifier circuit?
And What is the function of Rg?
Rg is a pull-down resistor and also determines the input impedance of our amplifier.
Because the input resistance of the FET itself is very high (many megohms) then the gate resistor is added to allow the coupling capacitor at the input to charge up and discharge in a reasonable time but not fast enough to cause loss of signal.
So, if the input was steady at zero volts and was suddenly increased to 3 volts, the capacitor will pass this change to the gate of the FET because it doesn't (or shouldn't) have time to charge up through the resistor Rg.
But if the input stayed at 3 volts, then the capacitor needs to charge up to 3 volts via Rg so that the voltage across Rg again became zero until any change came along.
The resistor value can be calculated by making it large compared with the reactance of the capacitor at the lowest frequency you want to pass to the gate of the FET.
For example, if the capacitor was 0.01 uF and you wanted to pass a frequency of 300 Hz, the capacitor would have a reactance of 53000 ohms. So, you might make Rg twenty times that, or 1 Megohm.
The capacitor could still charge up in 10 mS, but a 300 Hz signal would have changed polarity several times before that happens.
However, a more permanent change in the input voltage will cause the capacitor to charge up and the voltage on the gate of the FET to return to zero.
If Rg were not there, then the gate of the FET would be dragged to the DC input voltage for many minutes and would probably give no output due to incorrect bias conditions.
Thx vk6kro for a brief explanation and Jony130! ! :)
I am familiar with the concept of gate resistance, Rg, in JFET (junction field-effect transistor) amplifier circuits. Rg is a crucial component in these circuits as it controls the input impedance and the gain of the amplifier.
To calculate Rg in a JFET amplifier circuit, we first need to determine the desired input impedance, which is typically set by the manufacturer or the circuit designer. Then, we can use the following formula: Rg = (Vgs / Idss) * (1 - gm * Rl), where Vgs is the gate-source voltage, Idss is the drain-source current at zero gate-source voltage, and gm is the transconductance of the JFET. Rl represents the load resistance connected to the drain of the JFET.
The function of Rg is to provide a controlled resistance between the gate and the source of the JFET, allowing for proper biasing and signal amplification. It also helps to stabilize the amplifier circuit and prevent unwanted oscillations. Additionally, Rg helps to match the input impedance of the JFET with the source signal, ensuring maximum power transfer and minimizing signal distortion.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
