Integrating Polar Curves over Period
samtouchdown
Hello. I am having trouble conceptualizing and/or decisively arriving to a conclusion to this question. When finding the area enclosed by a closed polar curve, can't you just integrate over the period over the function, for example: 3 cos (3θ), you would integrate from 0 to 2pi/3? It intuitively seems so but graphically I am integrating where the curve is not there . Thanks in advance for the help.
The answer is no. You need to examine the graph. Part of the problem is that r can be negative so the graph isn't where you would expect for a given ##\theta##. If you draw the graph of your example, you will find that it is a 3 leaved rose which is completed as ##\theta## goes from ##0## to ##\pi##.
No. It will not always be from 0 to what makes the inside of the trigonometric function 2\pi. Here, 0 to \frac{2\pi}{3} will only give one loop. Since cos\left(n\theta\right) gives n loops when n is odd, there are three loops, or petals, here. Going from 0 to 2\pi will only give you one loop. Thus, you would have to go from 0 to 6\pi to get the whole function. But because the inside of the function is 3\theta, plugging in 2\pi will give you the whole thing.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
