Accuracy of a gravitational force approximation
The discussion focuses on approximating the gravitational force on an object at height h above Earth's surface using a power series. Part (a) is confirmed to be correct, expressing the force F in terms of h/R. In part (b), the user seeks to apply the Alternating Series Estimation Theorem to determine the range of h for which the approximation F ≈ mg is accurate within 1%. The conclusion reached is that h should be less than or equal to 32 km to maintain this accuracy, which can be verified through plotting. The user successfully navigates the application of the theorem and clarifies their understanding of the estimation process.
DivGradCurl
It seems to me that I've got part (a) right, but I'm not so sure about what I have in part (b). I just need to know whether or not I am on the right direction. Any help is highly appreciated. :smile:
Problem
The force due to gravity on an object with mass m at a height h above the surface of Earth is
F=\frac{mgR^2}{(R+h)^2}
where R is the radius of Earth and g is the acceleration due to gravity.
(a) Express F as a series of powers of h/r.
(b) Observe that if we approximate F by the first term in the series, we get the expression F\approx mg that is usually used when h is much smaller than R. Use the Alternating Series Estimation Theorem to estimate the range of values of h for which the approximation F \approx mg is accurate within 1%. (Use R = 6400 \mbox{ km}).
My work
(a)
(R+h) ^{-2} = \frac{1}{R^2} \left( 1 + \frac{h}{R} \right) ^{-2}
(R+h) ^{-2} = \frac{1}{R^2} \sum _{n=0} ^{\infty} \binom{-2}{n} \left( \frac{h}{R} \right) ^n
(R+h) ^{-2} = \frac{1}{R^2} \left[ 1 + \frac{(-2)}{1!} \frac{h}{R} + \frac{(-2)(-3)}{2!} \left( \frac{h}{R} \right) ^2 + \dotsb \right]
(R+h) ^{-2} = \frac{1}{R^2} \left[ 1 -2\frac{h}{R} + 3\left( \frac{h}{R} \right) ^2 - 4\left( \frac{h}{R} \right) ^3 + \dotsb \right]
(R+h) ^{-2} = \frac{1}{R^2} \sum _{n=0} ^{\infty} (n+1) \left( -\frac{h}{R} \right) ^n \Longrightarrow F = mg \sum _{n=0} ^{\infty} (n+1) \left( -\frac{h}{R} \right) ^n
(b)
The value of mg doesn't seem to matter here. So, I consider just the terms in the series. It seems to me that the easiest way to go is to plot
\left| 1 - \sum _{n=0} ^{N} (n+1) \left( -\frac{h}{R} \right) ^n \right|
I've tried this with:
N=1000
Domain: [0,37 \times 10^3]
Range: [0,0.01].
It gives a reasonable picture to estimate that h \leq 37 \times 10^3 \mbox{ m}. Is there a better way to find this? Am I on the right path at all?
Thank you
(a) looks fine.
For (b) you are required to use the Estimation Theorem for Alternating Series. For an alternating series with decreasing terms that converge to 0 for large n :
|S_{\infty} - S_n| \leq t_{n+1}
I have a question. I can't find an example in my textbook of the Alternating Series Estimation Theorem in a similar context. I know how to apply it in
e = \sum _{n=0} ^{\infty} \frac{1}{n!} \Longrightarrow t_{n+1} =\frac{1}{(n+1)!} < \left| \mbox{error} \right|
but not really in
e^x = \sum _{n=0} ^{\infty} \frac{x^n}{n!} \Longrightarrow ? < \left| \mbox{error} \right|
Which of the following is correct?
t_{n+1} = (n+2) \left( \frac{h}{R} \right) ^{n+1} < 10^{-2} = \left| \mbox{error} \right| \quad (1)
t_{n+1} = (n+2) \left( \frac{1}{R} \right) ^{n+1} < 10^{-2} = \left| \mbox{error} \right| \quad (2)
I'm just a bit confused. :smile:
Thanks
This one : (the other is dimensionally incorrect)
Ok. Now, we have an inequality and two unknowns---namely, n and h. What kind of trick is then required so that I am able to estimate h properly? I think it involves plotting, but I'm not sure how---for the very same reason. :confused:
I've just seen my problem in a different way, and it seems to work.
From part (a), we have:
F = mg \left[ 1 - 2\left( \frac{h}{R} \right) + 3\left( \frac{h}{R} \right) ^2 - \dotsb \right]
Applying the Alternating Series Estimation Theorem gives:
b_{n+1} = 2 \frac{h}{R} \leq 10 ^{-2} \Longrightarrow h \leq 32 \mbox{ km}
which can be visually verified with the aid of a plot.
