What causes rotation, a coupe or a moment?
  • Thread starter Thread starter Sarin
    Moment Rotation
The discussion centers on the physical significance of moments and couples in causing rotation. It questions whether moments are merely theoretical constructs or if they have tangible effects in real-world scenarios. A couple, defined as two equal moments acting in opposite directions, is highlighted as a specific case of a moment. The conversation also explores the behavior of an extended bar or rod in space when a force is applied to one end, concluding that it would move in the direction of the applied force. Overall, the complexities of material behavior and deformation in practical applications are acknowledged.
Sarin
Does a moment have any real (physical) significance or is it just a definition/ an aid to understand and calculate a couple. Is it that the rotation is actually caused by a couple!
I know we can resolve a force causing a moment about a point into a couple and an equal force acting at that point, but what i want to know is how does this actually happen in a real world scenario.
Also,
Say if there was a body (an extended bar or rod) in space so that no force would act on its centre of mass, then if a force F was applied on one of its ends what would happen and why?
forgive me if the question sounds stupid, but this concept has ben bugging me for a very long time now!:confused:
A couple is a special case of a moment when 2 equal moments act in opposite direction about a pivot.
The resolving of forces is (in my opinion anyway) a useful mathematical tool but in real life such things as the material constituent behaviour come into play and things get much more complicated, especially if the material deforms.
It would move in the direction of the applied force.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
