Rates of reaction experiment SPA
The discussion revolves around a student's experience with an O-level SPA experiment involving the reaction between acidified potassium iodide (KI) and hydrogen peroxide (H2O2). The student inquired about the necessity of labeling the volume of distilled water used in the experiment, as they only recorded the volumes of H2O2, the solution before KI addition, and KI itself. It was clarified that as long as the total volume of the solution, including distilled water and reactants, was provided, it sufficed for calculations. The consensus is that specifying the volume of water added for dilution is not critical, provided all reagent volumes are accurately recorded. This ensures that the total volume can be used to calculate concentrations effectively.
sgstudent
Hi today I took my O levels spa and the reaction was acidified KI+hydrogen peroxide. Once we see a slight colouration, we stopped timing the stopwatch. We were told to draw a tabulation box with the information in the experiment. Also we were told to clearly show the total volume of the solution before the additional if the second reactant (we diluted one of the reactants). However, I didn't put a heading as "volume of distilled water". Is that very important to write that down? I had only put volume of H2O2/cm3, volume of solution before KI was added/cm3, volume of KI/cm3 and time taken for blue colouration to appear/s. Thanks for the help!
Chemistry news on Phys.org
You need to know total volume to be able to calculate concentrations.
Hi Borek I did give the total volume of distilled water+reactants so that good enough?
If I understand you correctly, it doesn't matter - recording volume of water added for dilution and final volume is equivalent (assuming you correctly recorded volumes of all reagents).
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
