Derivative of a trig. function
frosty8688
1. Find the derivative of the function using the power rule or product rule
2. sinθ/2 + c/θ
3. I tried to do plus or minus the √1-cosθ/2
Your question is ambiguous. Please use parentheses. It looks like that want to find the derivative of
\frac{\sin \theta}{2} + \frac{c}{\theta}
Yes, that's it
There is no need to plus or minus the √1-cosθ/2, simply find the derivative of sin θ and 1/θ w.r.t θ (I suppose that's what you are asked.) And what about c? How is it defined in the question?
Here's what I have (cosθ/2) + (c/θ). c is a variable.
The c probably stands for some constant.
ok, thanks.
If c is a constant, and the above is your solution attempt, then you have to do something with the 2nd term (ie. the derivative of c/θ isn't c/θ).
The solution would be (cosθ/2).
No, how do you get this? What's the derivative of 1/θ?
The derivative of a constant is 0.
Sorry, that's wrong. If the original problem was this:
\frac{\sin \theta}{2} + c
(with c as a constant), then your answer would be right. But the 2nd term has a θ in the denominator. What do we do?
It would be (cosθ/2 - c/θ^2)
Looks good.
