16inch rotatable pipe flange joint
  • Thread starter Thread starter NTzionIST
    Joint Pipe
A user is designing a dust cleaning system for induction furnaces, requiring a mechanism for a 7m long, 16-inch diameter pipe to rotate about an elbow without leaks. They seek advice on whether constant rotation is necessary or if a limited oscillation would suffice. The discussion considers using a sleeve over the joint for sealing but acknowledges potential issues with wear due to temperature and movement. Submerging the joint in water is suggested as a possible solution to prevent dust leakage, although it may not be viable if the pipe is extremely hot. A potential solution involves using a braided stainless steel hose that could flex while maintaining a fixed seal.
NTzionIST
I am making a dust cleaning system for induction furnaces in my steel mill and for that I have to design a mechanism with which about 7m length of 16inch diameter pipe can rotate about an elbow attached to one end but wihtout any leakages. ANY HELP would be appreciated.
Do you need the capability of constant (ie. >360°) rotation, or is back-and-forth like an oscillating fan okay? If the latter, could you sleeve over the joint for sealing as opposed to having the joint itself leak-proof?
No I just need a rotation of about 40 degrees. I did think about the sleeve over the joint but I guess the seal will have the same problem of wearing out because of the temperature as well as movement.
Would it be cheaper to submerge the joint in water?
That would solve the dust leakage at least, unless the pipe is white hot and has to stay that way.
I was actually thinking of having the seal not move at all. Something along the line of braided stainless steel hose might be able to flex and twist enough that the ends could be bonded to the pipe.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
