Trigonometric identities hard question
The discussion focuses on simplifying the expression sin(b)/cos(b) + cos(b)/sin(b). Participants confirm that the initial transformation to tan(b) + cot(b) is correct but not the final simplification. The key suggestion is to use a common denominator to combine the fractions, which leads to a more surprising result. Ultimately, the expression simplifies to 1/(cos(b)sin(b)). Understanding this method is essential for tackling similar trigonometric identity problems effectively.
DJ-Smiles
Simplify the following:
Ok so i have no clue how to do this,I keep trying but can't seem to get the right answer, I have tried to do this:
=tan(b)+ 1/tan(b)
=tan(b)+cot(b)
I know this isn't right and I am encountering these types of questions quite often now, so I really need help. Please help me.
=tan(b)+ 1/tan(b)
=tan(b)+cot(b)
Well, it is true that sin(b)/cos(b) + cos(b)/sin(b) = tan(b) + cot(b) , but you probably need to come up with something more surprising.
Use a common denominator to combine sin(b)/cos(b) + cos(b)/sin(b) into one fraction. Yo may be surprised by what the numerator simplifies to.
yeah I know it's just that the answer is 1/cos(b)sin(b). How would I get to this?
As I said before,
se a common denominator to combine sin(b)/cos(b) + cos(b)/sin(b) into one fraction.​
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
