How Do You Correctly Solve Vector Addition Problems?
  • Thread starter Thread starter APphysicsfail
    Vector
To solve vector addition problems correctly, first break down each vector into its x and y components. For the given vectors, the components were calculated as Ax=3.96 km, Ay=9.18 km for the first vector, and Bx=21.29 km, By=13.11 km for the second. The resultant vector is found by summing these components, not by treating them as sides of a quadrilateral. After obtaining the final x and y components, use the Pythagorean theorem to find the magnitude of the resultant vector and the arctangent function to determine the angle. This method ensures accurate results, addressing concerns about the resultant being shorter than one of the original vectors.
APphysicsfail
I know that this is a simple concept, but I've been working on this for so long and I feel like I'm doing the wrong thing.
Add these vectors: 10 km [S53°E] and 25 km 16.26° N of E
Law of cosines and law of sines equations
So I visualized the vectors as two arrows, the shorter one pointing down at a 323° angle (of 53° east of south) and the longer one starting at the tip of the first one, pointing up 16.26°. My first attempt was to split them up into components- I drew legs off of the lines to make right triangles and used trig to calculate Ax=3.96km, Ay=9.18km, Bx=21.29 and By=13.11 with Ax/Ay being the components of the 10km line, Bx/By the components of 25km. I then realized that the resultant line I was looking for wasn't going to be the hypotenuse of a triangle but the side of a quadrilateral, so finding the components was useless.
Then I found the supplementary angle between 37° (the compliment of 53°) and 16.26° to be 126.74°. I used the law of cosines to find the length of the resultant, with 126.74° being my angle C and the resultant being c.
c^2 = a^2+b^2 - 2ab(cosC)
c^2 = 10^2+25^2 - 2(10)(25)(cos126.74)
c^2 = 487.7
c = 22.08
I feel like I'm doing this wrong, since it's odd that the resultant is shorter than the second vector. I went on to plug this information into the law of sines to find the angle of the new vector, using 25 as B, 22.08 as C, 126.74 as c and looking for b.
sinb/B = sinc/C
sinb/25 = sin126.74/22.08
b = .665°
53°+0.665 = 53.665° E of S.
So the answer I got is 22.08km 53.665 E of S. I'm positive that this is wrong. Could someone please explain to me how this works and what I'm doing wrong? If my phrasing of the question is confusing, ask me any questions you have and I'll try convey it clearer. Thank you!
first determine x y components of each vector then add x comps and y comps to get the final vector then use pythagorean theorem to get dist and the y/x = tan (theta) to get angle.
