Archived What angle maximizes the horizontal distance of a rocket launch?
The discussion focuses on determining the optimal launch angle for maximizing the horizontal distance of a rocket with a thrust stage followed by a projectile stage. The rocket experiences a thrust of 3.42 N for 0.33 seconds, followed by a delay of 1.74 seconds before an ejection charge activates, causing it to drop. The goal is to ensure the ejection occurs before the rocket impacts the ground, allowing for safety leeway. The user has utilized a spreadsheet and the goal seek function to adjust the launch angle to achieve the desired timing. A quadratic equation for vertical acceleration is derived to solve the problem analytically, emphasizing the importance of timing in maximizing distance.
RobertL
Hey everyone,
I've been trying to do a problem in which I attempt to find the angle that maximizes the horizontal distance of a rocket, which has a stage with thrust and then a stage as a projectile. After a delay period, an ejection charge fires and causes the rocket to drop straight down. I want to have the ejection charge to fire before the rocket hits the ground, which means giving a bit of leeway.
If any of you can look over my work and give me any suggestions, I would greatly appreciate it.
Thrust: 3.42 N
Burn Time (constant thrust assumed): .33s
Delay time before ejection charge fires after burn time: 1.74s
Mass: .033893kg
Other values are calculated in the spreadsheet.
Equations of motion/projectiles
See spreadsheet. In it, I attempted to use the goal seek function to set the total time since burnout equal to the delay time (1.74s) by changing the value of the angle.
Thanks for any ideas!
The maximal distance will be reached if the rocket is just above the ground after 1.74 seconds. Safety factors can be added as necessary. Assuming a constant thrust vector, this leads to a quadratic equation for the vertical acceleration, which can be solved analytically.
