Determine the distance the sled will slide before coming to rest.
  • Thread starter Thread starter ExtendedG
A sled slides down a 6-degree hill with an initial speed of 12 m/s and a coefficient of friction of 0.14. To determine how far it will slide before stopping, the forces acting on the sled must be analyzed using Newton's second law. The net force equation includes gravitational and frictional forces, which depend on mass. The coefficient of friction indicates that mass may cancel out in the calculations, simplifying the problem. A free body diagram and proper equations are essential for solving the sled's displacement before coming to rest.
ExtendedG
A sled takes off from the top of a hill inclined at 6 degrees to the horizontal. The sled's initial speed is 12 m/s. The coefficient of friction between the sled and the snow is 0.14. Determine how far the sled will slide before coming to rest.
F=ma
vFsquared=vIsquared + 2a(d)
vf= velocity final vI= initial velocity a=accel. d=displacement.
Well I didn't get very far because I don't have enough variables, I need mass! I obviously need to find accelerating, what would my f=ma statement be? I thought it would be Fapp - Ffriction = ma...help?
Perhaps worth remembering the definition of coefficient of friction. It's the ratio of two forces one of which depends on the mass. This means that mass sometimes cancels in some problems so it's not allways needed.
Draw the free body diagram and write equations for the forces.
F=ma
Fg - Ff = ma
mgsin(theta) - umgcos(theta) = ma
I have two masses to remove, not just one :/ So i can't just simply simplify to:
gsin(theta) - ugcos(theta) = a right?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
