2 people pulling on ropes or cables with a third person trying to equal out
  • Thread starter Thread starter SherBear
    Cables
To achieve equilibrium in the system with Wesson pulling 300N at 30° in the negative y and x quadrant, Canola pulling 200N at 30° in the positive y and x quadrant, and Olive pulling 250N at 60°, the calculations involve resolving the forces into their components. The sum of the forces in the x-direction results in 166.5N, while the y-direction sums to zero. Using Pythagorean theorem, the required magnitude of Olive's force is calculated to be approximately 52.17N. The direction of this force is determined to be 0°, indicating it acts along the positive x-axis. The calculations confirm that the approach to finding the equilibrium force is correct.
SherBear
We have a person pulling on a string or rope in the negative y negative x quadrant (call it left) this person is called Wesson, they have a force of 300N at 30°
Same situation but pulling the other way, positive y and positive x quadrant (call it right), this person is called Canola, they have a force of 200N at 30°
The third person pulling is the boss called Olive, they have a force of 250N at 60°
What I'm seeking is this: What is the magnitude and direction of the force the boss needs to apply to make the system at equilibrium?
First make a FBD then..
I have the sum of Fx = -tw + tc + to = 0
Pithagoram's theory
arc tan...Tan-1 (Fy/Fx)
from the sum of Fx I have = -300N sin 30° + 200N sin 30° + 250N sin 60°
-150 + 100 + 216.50=
Fx=166.5
To get the magnitude I'm using pithagorm's theorm
so I have sqrt 166.5^2 + 0 (because the sum in the y dir is zero)
magnitue= 52.17N
To get the direction I have
Tan -1 (0 / 166.5N) = 0 N = Direction
Am I on the money or way off base?
We have a person pulling on a string or rope in the negative y negative x quadrant---**Sorry about that, to be left, I meant positive y and negative x quadrant =-)**
For this one I have
wesson= -300cos30 ihat + 300sin30 jhat=-259.80 ihat + 150 j hat
canola= 200 cos 30 ihat + 200 sin 30 jhat= 173.20 i hat + 100 j hat
then add..........= 433 i hat - 50 j hat
magnitude= sqrt 433 ihat ^2 + -50 jhat ^2=
435.87N=magnitude
Direction= Tan-1 50jhat / 433 i hat=
Direction=6.58 degrees above the positive x-axis or north of the positive x axis
is this right?
