Statistics Problem: finding a PDF using the CDF technique
_Steve_
Hey guys, I'm stuck on a question in my homework assignment and I was wondering if you could push me in the right direction? So here's the question:
X and Y are continuous random variables with joint pdf f(x,y)= 4xy (0<x<1, 0<y<1, and otherwise 0). Find the pdf of T=X+Y using the CDF technique.
So this is how I started off, I first let G(t) be the CDF of T, then I look at three different cases:
t<=0: G(t) = P[X+Y<=t] = 0
t>=2: G(t) = P[X+Y<=t] = 1
0<t<2: G(t) = P[X+Y<=t] = ?
So here I'm a little confused, I'm trying to figure out the limits of the double integral I'm supposed to take, I think I might have to take one integral from 0<t<1, then another from 1<=t<2, but then I'm stuck with two "functions" (one from (0,1), one from [1,2)) for my g(t). Are there any possible limits for this double integral that would save me from having to separate 0<t<2 into two double integrals?
You are correct in that you do need different integrals for t > 1 and t < 1. If you use the cdf method this is unavoidable. (Other, completely different, methods are easier, but you are told not to use them.)
RGV
RGV
Oh, okay, so how do I get a g(t) with only one function from 0<t<2 instead of having:
g(t)={f(t), t<1
h(t), t>1)
Does it make sense to write:
G(t)={0, t<0
F(t), t<1
H(t), t>1
1, t>2}
as:
G(t)={0, t<0
F(t)+H(t), 0<t<2
1, t>2}
EDIT: Nevermind, I think I was doing the other part of the question wrong.. thanks for your help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
