Two questions on ideal gases and heat
The discussion revolves around solving two physics problems related to ideal gases and heat transfer. The first problem involves calculating the heat absorbed by air in a cylinder with a piston, where the work done is derived from the piston's acceleration and the specific heat of air. The second problem addresses the mass of air that escapes from a room when the temperature increases from 10°C to 25°C, utilizing the ideal gas law and the relationship between pressure, volume, and temperature. Participants clarify the assumptions of constant pressure and the implications for calculations, leading to a conclusion that approximately 6.32 kg of air left the room. The conversation emphasizes understanding the relationships between pressure, volume, and temperature in gas behavior.
feijjjao
A horizontal cilindre with a piston of mass M = 0.5 kg is filled with air (the specific heat of air is Cp = 1000 Joule/Grad*kmole). The heating of the gas results in the piston's accelerated displacement (with constant acceleration) until the velocity v = 1 m/s. Determine the amount of heat acumulated by the gas during the heating. The energy of one gas mol is U = Cp*T. Ignore the external pressure and the thermical capacities of both the cilindre and piston. The universal gas constant is R = 8.31*10³ Joule/Grad*kmole.
The volume of a room is 100m³ with ambient pressure of 1.02*10^5 Pa. Determine the air mass which left the room after the raise in temperature from 10°C to 25°C. The air density in normal conditions (To = 273K, p0 = 1.01*10^5 Pa) is 1.29kg/m³.
General gas equations, minding the circumstances:
P1V1 = P2V2
P1/T1 = P2/T2
V1/T1 = V2/T2
PV = nRT
Energy conservation
dU = dQ - dW
I guess the solutions comes out rather simply once you know the conditions. The problem is I don't exactly know how the various factors (pressure, volume, density) are linked, how they affect each other. And thus I have no ground for assumptions. Could someone explain these for me? Thanks!
Consider the different parameters: P,V,T : are any of them constant?
The work done is W = ∫F dx = ∫m a dx = m∫a dx (from 0 to distance x)
a = dv/dt = (dv/dx)(dx/dt) = (dv/dx)v → a dx = v dv
→ ∫a dx (from 0 to distance x) = ∫v dv (from 0 to 1 m/s).
Thus, W = m∫v dv (from 0 to 1 m/s) = mv^2 /2
Assuming constant pressure (since you provided Cp for air), we have that the work done is:
W = ∫P dV = P∫dV = PV2 - PV1 = nRT2 - nRT1 = nRΔT. Hence, ΔT = W/nR.
Thus, the amount of heat absorbed by the gas = U + W = CpΔT + W = W(1 + Cp/(nR)) =
= mv^2(1+Cp/(nR))/2
Assuming only one mol (since you provided U for 1 mol):
Q = mv^2(1+Cp/(1 mol * R))/2
@LoadedAnvils:... usually we like to encourage people to do their own homework: the idea is that people learn best by doing the work themselves. What we normally do is try to help them get unstuck.
Oh, thanks LoadedAnvils! Our professor tries to avoid the use of calculus in questions he himself makes, so I didn't even thought of that. Well, guess it was needed this time! Thanks!
Simon Bridge, I think you can consider the pressure being constant, right? I was a little lost because I thought the room was closed, and then someone goes and, I don't know, drill a hole on the wall to make the air come out.
So, since pressure is constant, we have
V1/T1 = V2/T2
V2 = (100*298)/283 = 105,3 m³
or, 5,3 m³ of air left the room.
Now we have to find the air density, say d2, under the new conditions. In the normal conditions, we have
d = m/V0 = 1,29 kg/m³
and so
V0 = m/1,29
Using Clayperon's equation for the final condition and the normal condition,
P0V0 = nRT0
P2V2 = nRT2
or
V2 = (P0*V0*T2)/(P2*T0)
And thus
d2 = m/V2 = (m*P2*T0)/(P0*V0*T2) = (d*P2*T0)/(P0*T2) = 1,193 < 1,29
So the mass which left the room is 5,3 * 1,193 = 6,32kg.
Could someone confirm this result for me? Thanks!
