Thermodynamics - Calorific Capacity
The discussion focuses on deriving the total differential of entropy (dS) and volume (dV) in a thermodynamic system with constant particle numbers. The user correctly expresses dS in terms of temperature and volume derivatives, incorporating the calorific capacity at constant volume (CV). However, confusion arises regarding the interpretation of partial derivatives, particularly in equating terms involving constant pressure assumptions. The key issue is the inconsistency in applying the definitions of the partial derivatives, which affects the final relationship between CP and CV. Clarification on the proper use of these derivatives is necessary for accurate results.
Jalo
Consider a system with a constant number of particles.
Write the total differential dS in terms of the derivarives \frac{∂S}{∂T} and \frac{∂S}{∂V}. Introduce CV (calorific capacity at constant volume).
Next write the total differential of the volume dV in terms of the parcial derivatives \frac{∂V}{∂T} and \frac{∂V}{∂P}. Assume that the pressure is constant. Show that the result comes in the form of:
CP-CV= Expression
CP=T\frac{∂S}{∂T} , P and N Constant
CV=T\frac{∂S}{∂T} , V and N Constant
First I wrote the differential of the entropy as asked:
dS = \frac{∂S}{∂T}dT + \frac{∂S}{∂V}dV
I know that \frac{∂S}{∂V} = CV/T. Substituting I get:
dS = CV/T dT + \frac{∂S}{∂V}dV
Next I found the differential of the volume:
dV = \frac{∂V}{∂T}dT + \frac{∂V}{∂P}dP
Since the pressure is constant it reduces to the form
Substituting in our dS expression we get:
dS = CV/T dT + \frac{∂S}{∂V}\frac{∂V}{∂T}dT =
= CV/T dT + \frac{∂S}{∂T}dT =
= CV/T dT + CP/T dT ⇔
⇔ T\frac{dS}{dT} = CV + CP
I'm making some mistake. If anyone could point me in the right direction I'd appreciate.
Thanks!
I think your problem is a confusion over the meanings of different partial derivatives. Your use of ##\frac{∂S}{∂V}## refers to changing volume, keeping temperature constant.
That's inconsistent with later equating ##\frac{∂S}{∂V}\frac{∂V}{∂T} = \frac{∂S}{∂T}##, which, to be valid, assumes pressure constant in all terms.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
