Which wheel loses traction first?
  • Thread starter Thread starter aortucre
    Traction Wheel
When driving a rear-wheel-drive car too fast around a corner, the inner wheels can lose down-force due to mass transfer, potentially leading to oversteer. The discussion highlights the importance of understanding how weight distribution affects traction, particularly with a limited slip differential like a Torsen LSD. To prevent the rear inner wheel from slipping, the design of a dynamic spoiler is proposed to increase downforce on that wheel. Calculating the necessary downforce involves considering the total weight on the wheel and the gyroscopic effects during turns. Understanding these dynamics is crucial for optimizing performance and preventing loss of traction.
aortucre
When you drive a real wheel drive too fast around a corner, the two inner wheels lose some down-force due to mass transfer. If you oversteer, does the rear inner wheel lose traction first? And then trigger the oversteer?
If so, are there any equations to determine how the weight is distributed knowing the total mass of the car, the distance between wheels, the height of the CG, etc...?
Thank you in advance for any help!
hello and welcome..loss of traction depends on if it is an open or limited slip differential. I recommend you look at a post in Automotive Engineering section called Race Car Suspension Class..
Hello and thanks for your fast answer.
The car we are using has a limited slip differential. More specifically a Torsen LSD.
I will read that post and come back as soon as I can.
What we are trying to do is a "2 wing dynaimc spoiler" that will raise its left or right half to provide the needed downforce to the rear inner wheel so that it won't slip. What we are trying to figure out is how much of the total weight is being put on that wheel, and how much does it need so that it doesn't slip. The difference will be provided by the spoiler.
Thanks again
Any tips or ideas? Thanks guys!
In general to determine distribution of forces when a car takes a turn, you must consider gyroscopic effect equations. That shows how a moment is created to lift the inner wheels while taking a turn.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
