Is Element Transmutation Through Fusion or Fission Feasible?
Element transmutation through fusion or fission is theoretically possible, primarily through nuclear reactions, but it is limited to specific reactions that yield desired elements. While physics labs have achieved transmutation, commercially viable products are mainly trans-uranium elements used in applications like smoke detectors. The process involves complex reactions, often resulting in a mix of products rather than a single desired element. A breeder reactor utilizing neutron bombardment is suggested as a feasible method for achieving transmutation. Overall, while the concept is intriguing, practical limitations and specific conditions govern the outcomes.
pattonmarquis
Hello, I wanted to know if it was possible to create a machine that can convert elements to those of your choosing? The most likely canadidate(and only canidate) is transmutation by fusion or fission. I know this is a physics forum but this stuff is covered in physics and you guys are pretty smart. How would this be possible, not possible, etc. It was achieved before by the way. Note that energy required and radiation should not be a problem. If theoretically possible then what applications obvious or not, would they have.
There are such things - physics labs have this capability. The only commercially valuable products are trans-uranium elements used in for example CO or smoke detectors (?).
You can't choose any element you want. It has to be a product of some technically achievable nuclear reaction. There can be several competing reactions going on, so you end up with a mix of various products, most of which are probably not what you want.
Your best best is probably some kind of breeder reactor which uses neutron bombardment to convert some elements to some nearby elements.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
