Which Calorimeter Is Better for Minimizing Experimental Interference?
  • Thread starter Thread starter jzq
    Calorimetry
When comparing two calorimeters, one with a heat capacity of 10.53 calories/°C and the other with 104.3 calories/°C, the calorimeter with the lower heat capacity is generally preferred. This is because it has less interference with experimental results, allowing for more accurate measurements. However, knowing the heat capacity of either calorimeter enables researchers to adjust their calculations accordingly, ensuring accurate data interpretation regardless of which calorimeter is used.
jzq
I am comparing two calorimeters. One has a heat capacity of 10.53 calories/degrees celsius and the second one has a heat capacity of 104.3 calories/degrees celsius. I just need to know which one is better and why.
Chemistry news on Phys.org
The one with lower heat capacity is considered better because it will interfere less with your experiments. But as long as you know the heat capacity you can go back and make the proper calculation for the data that you're interested in.
Thanks a lot noobie!
