Hooke's Law: How to find Amplitude
Hooke's Law relates to the motion of springs, described by the differential equation x'' + wx = 0. The general solution is A sin(wt) + B cos(wt), where A and B are constants representing the initial conditions of the system. The amplitude of the motion is calculated as the square root of the sum of the squares of A and B, or sqrt(A^2 + B^2). This relationship arises from the trigonometric identity used to express the solution in a more recognizable form, A cos(ωt + φ). Understanding these constants is essential for grasping the physical meaning of amplitude in simple harmonic motion.
Absent.Crisis
Hello all,
(Newbie here so I hope I'm posting this in the right section, if not please guide me to the correct one)
I'm studying Hooke's Law in Physics and there is something I can't understand.
The equation for the Simple Harmonic Motion of a spring is given by x'' + wx =0
the general solution for the Differential equation above is given by: A sin (wt) + B cos (wt)
I came across a reference book that says: the amplitude is given by:
sqrt {A^2 + B^2}
I'd like to understand how they got this?? Right now I know that w is the angular frequency and wt gives the phase angle, but A and B as constants make no sense to me, what are they and what do they mean physically?
Any kind of answer would be greatly appreciated, please help me understand!
Thanks in advance!
A more recognizable form of the general solution would be this:
A\cos (\omega t + \phi)
Where A is the amplitude. Expand this (using a trig identity) and compare with the form you were given.
Thanks a lot, I got it now :D
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
