Vector Valued Function Spaceship Problem
Baumer8993
The position function of a spaceship is r(t)= < 3+T, 2+ln(T), 7 -(4/T2+1)> , and the coordinates of a space station are (6, 4, 9). The captain wants to coast into the space station. When should the engines be turned off?
I took the derivative of the position function to get the velocity function:
V(t)= <1, (1/T), (8T)/(T2+1)2
Right now I have a vector I called U =<6-3+s>, 4 -(2+ln(s)), 9-[7-(4/s2+1)]
I got this hint from my professor. I understand that this is the position vector to the spaceship at time s. I know I now need to find the velocity vector that is parallel to the position vector. My professor gave me the hint to multiply by a constant K in the velocity vector function. At that point I would have two equations, and two unknowns which is easy to solve. I am just stuck on when I multiply by the constant K what would I set the velocity vector function equal too?
When the engines are switched off, the spaceship will probably move in a straight line. So you want to switch them off when your velocity vector points from r(t) towards the space station.
This is a repost of
https://www.physicsforums.com/showthread.php?t=667299
Why are you reposting a question that has already been replied to?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
