Tensor gradient and maxwell's equation
steveurkell
Hi everyone,
I now have difficulties in using formula for gradient of tensor. The following is
tensor for field strength
Fsubscripts_alpha_beta =
[ 0 -Ex -Ey -Ez
Ex 0 Bz -By
Ey -Bz 0 Bx
Ez By -Bx 0 ]
My question is, how do we derive the Maxwell equations div(B) = 0 and curl(E)+dB/dt using gradient of tensor of the above field tensor?
I myself not quite sure how to use formula for tensor gradient, especially due to the additional term apart from the vectors and 1-forms that the tensor has
e.g.
del_zeta (S) = (dS/dx_superscript_delta) zeta_superscript_delta
What does zeta term here do?
I will be indebted if someone here could give a real example of how to find the gradient of a tensor with the tensor given in the example.
Thank you for any help
regards,
This borad has "tex" notation, you can click on any of the equations below to see the "tex" source, which makes it a lot easier to communicate.
I think you are asking about the covariant derivative operator
\nabla_a
What this does is it takes any tensor of rank p, and produces a tensor of rank p+1. A scalar counts as a tensor of rank 0 for this purpose.
If you think about it this should make sense - the partial derivative of a scalar is a vector. The 'a' represents the extra index in the new tensor, you start with a rank p tensor, you end up with a rank p+1 tensor, this means you add one index to the tensor, this added index is represented by the symbol 'a'.
If you have a nice orthonormal coordinate system, the covariant derivative operator reduces to the ordinary derivative.
Thus
\nabla_a f = (\frac{\partial f}{\partial t}, \frac{\partial f}{\partial x}, \frac{\partial f}{\partial y}, \frac{\partial f}{\partial z})
where I have replaced a_0, a_1, a_2, a_3 with t,x,y,z to make the point clearer.
Note that we started out with a scalar, and wound up with a one-form. The index a represents the components of that one form (the scalar didn't have any indices at all).
The covariant derivative is only equivalent to the partial derivative in orthonormal coordinate systems where the Christoffel symbols are all zero though.
I hope I've understood your question properly, I'm not positive I have. I realize I haven't answered your question about Maxwell's equations yet, but I want to see if the notation I'm using is the notation you are using.
Sometimes people use other notations and notions (like the exterior derivative) - but that would be symbolized by
dF
IIUC,you're trying to get from the covariant formalism to the noncovariant one.The equations:
\nabla\cdot\vec{B}=0(1)
\nabla\times\vec{E}+\frac{\partial\vec{B}}{\partial t}=\vec{0} (2-4)...
can be found by simply giving all 4 values to the subscripts in the field equations
\partial_{[\mu}F_{\nu\rho]}=0
(Pervect mentioned covariant derivative,but in this "fortunate" case
\partial_{[\mu}F_{\nu\rho]}\equiv \nabla_{[\mu}F_{\nu\rho]}=0 )
So do it...
Daniel.
P.S.Report any problems.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
