Comparing Series & Parallel Connections of Helmholtz Coils
Connecting Helmholtz coils in series or parallel affects their electrical behavior in relation to the circuit they are connected to. In a static setup, the coils behave like resistors, impacting the current flow and resulting magnetic field. When driven to produce a constant magnetic field, the field remains stable if the current is constant, particularly with identical coils. If the coils are driven by an oscillator, the magnetic field will oscillate in response to the changing current. The choice of connection method ultimately influences the magnetic field's characteristics and stability.
strokebow
Hi,
With the condition that 2 helmholtz coils are parallel with each other sharing the same axis in space . . .
What are the differences between electrically connecting up the coils in series and in parallel?
cheers
That depends on the circuit you connect them to. In a static setup, they are like resistors.
Thanks for your response.
In the case that they are being driven to produce a constant magnetic field between them.
The magnetic field is always constant if the current in coils is constant. And its second derivative vanishes if the coils are identical and have the same current inside.
The absolute value of the magnetic field there depends on that current, and that depends on the electric setup.
Thanks very much.
How would things differ if they were driven by an oscillator?
The magnetic field would oscillate as well.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
