Projectile Problem: Aim 10 Meters Above Target?
  • Thread starter Thread starter Gamerex
    Projectile
Aiming a projectile 10 meters above a target that is 10 meters below is not a straightforward solution due to the parabolic nature of projectile motion. The trajectory varies, and while there may be instances where a 10-meter difference is applicable, it does not hold true across all distances. Air resistance complicates the flight path, causing the projectile to drop more rapidly towards the end of its trajectory. The effectiveness of compensating for drop depends on the specific details of the trajectory and the range involved. Ultimately, the assumption that flight time remains constant for different elevations is flawed, leading to inaccuracies in aiming adjustments.
Gamerex
My physics instructor and I were arguing about this today. It was a problem involving ranges, but the fundamental issue is this:
If you aim a projectile at a target, and the projectile passes 10 meters below the target, do you aim 10 meters above the target to compensate?
I would say no. It's perhaps a useful approximation. The reason is ideal flight of a projectile is a parabola. You'd be shooting from the same spot both times. If you were to plot both trajectories out there may be one spot where the difference is 10m but not at all spots.
The real case is more complicated with air resistance blunting the parabolic flight causing the projectile to drop more quickly toward end of the flight. Again there's probably one spot where your 10m difference holds but not at all spots.
Wikipedia has an article on "range of a projectile"
That method of compensation will work to some extent but it depends upon the details of the trajectory. If the projectile dips 10m over a 50m range, aiming 10m high will not do the job. Over a km, the method will give a much better result. Compensating in this way relies on assuming that the flight time is the same for both elevations (and, hence, the amount of drop). In fact, it never is the same but the error is less for a less curved, flatter, trajectory (as with the high velocity 1km example).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
