How Long Does It Take for a Father to Catch His Son if He Accelerates from Rest?
  • Thread starter Thread starter kencamarador
    Acceleration
The discussion centers on a physics problem involving a father chasing his son, who is running at a constant speed of 3.0 m/s while the father accelerates from rest at 1.5 m/s². Participants clarify that the father's initial velocity is zero, and they explore the conditions under which the father will catch up to the son, specifically focusing on the equality of their displacements over time. The conversation emphasizes the need to express the displacement of both the father and son in terms of time to find the solution. Ultimately, the goal is to determine the time it takes for the father to catch his son.
kencamarador
A boy is running a a constant velocity of 3.0 m/s [E] and passes his father who is standing still. The father immediately starts to chase his son with a constant acceleration of 1.5m/s at the instant his that his son reachers him
How long does it take the father to catch his son?
Am I correct?
Initial Velocity is 3.0m/s [E]
Average Acceleration is 1.5m/s^2
But what is my V final?
Am I correct?
Are you saying the initial velocity of the father is 3.0m/s?
When the father does catch up to the son, what two quantites - v1,v2,a,d or t - will they have in common?
There are two different objects moving, boy and father. The boy moves with constant velocity. The father moves with constant acceleration with zero initial velocity. Father catches the son when they are at the same place again, that is the displacements are equal. Write up the displacement of both in terms of time.
ehild
