In which direction ball will move?
  • Thread starter Thread starter ash64449
    Ball Direction
A ball in uniform motion is influenced by inertia and gravitational force, which act perpendicularly. The discussion revolves around determining the net direction of the ball's movement, suggesting that trigonometry could be useful for solving this. Responses indicate that the ball will move in a parabolic arc. New users are reminded to follow forum rules for posting homework questions, including providing the full question and an attempt at a solution. The conversation emphasizes the importance of clarity and adherence to posting guidelines in academic discussions.
ash64449
hello friends, a ball experiences uniform motion due to inertia and gravitational force which is acting downwards. Both these forces are perpendicular. So given these conditions,in which direction the ball will move? I think with the help of trigonometry we can solve this.. Since there are two direction force are acting,i think ball will move in net direction.. But i don't know which net direction...
Welcome to the forum. I see you are a first time poster. Can you check the rules for posting homework questions...
https://www.physicsforums.com/showthread.php?t=617567
In particular please post the whole question as set and an attempt at the solution.
EDIT: There are several ways to answer your question as posed. The simplest is "In a parabolic arc".
how to edit?? And i am in a mobile.but i didn't see any homework template..
You don't need to edit your first post. You can make a new one using the following headings..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
