If a rock is dropped off of a sea cliff
  • Thread starter Thread starter kbrowne29
    Rock
To determine the height of the cliff from which a rock is dropped, the problem is divided into two parts: the rock's fall and the sound's ascent. The correct equation for the rock's descent is X = 0 + 0 + (0.5)(9.8)t1^2, while the sound's return is represented as X = 340t2. The total time for both events is 3.4 seconds, leading to the equations t1 + t2 = 3.4 and (0.5)(9.8)t1^2 = 340t2. Solving these equations simultaneously allows for the calculation of the cliff's height. This method effectively combines the dynamics of falling and sound propagation.
kbrowne29
If a rock is dropped off of a sea cliff, and the sound of the rock hitting the water is heard 3.4 seconds later, how tall is the cliff, assuming the speed of sound is 340 m/s.
What I've been trying to do is break the problem up into 2 parts, one for the rock going down towards the sea, and one for the speed of sound going up the cliff. The problem is that I can't seem to substitute the right things into the equation x = x0 + v0t + .5at^2. For the going down part, the equation looks like the following:
X= 0 + 0 + (.5)(9.8)t^2. And for the going up part, I'm not sure whether the initial velocity of the speed of sound is 340 m/s, or whether it is zero. If the initial speed were 340 m/s, then the equation would (?) look like the following:
x = 0 + 340t + 0.
This is where I get stuck, and I don't know what to do with the two equations. I would greatly appreciate the help. Thanks.
Sound does not accelerate and is not affected by gravity!
Your calculation for the rock falling: X= 0 + 0 + (.5)(9.8)t^2 is correct. For the sound coming back up, X= 340t.
What you can do is write these as X= 0 + 0 + (.5)(9.8)t1^2,
X= 340 t2 and t1+ t2= 3.4.
You can solve the two equations (.5)(9.8)t1^2= 340 t2 and t1+ t2= 3.4 for t1 or t2 separately and then use the equations to find X.
Thank you very much for the help; your idea of creating the equation v1+ v2 = 3.4 is exactly what I needed to finish the problem off. I hadn't previously thought about solving the equations silmultaneously like that.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
