Quarter Manufacturing Force Estimate
To estimate the force needed to stamp an American quarter, key factors include yield strength and coefficient of friction of the materials involved. A significant press capacity can simplify the process, as it can handle the required force without needing to account for these variables. The discussion highlights the importance of understanding material properties in the stamping process. A link to a relevant coin stamping press is provided as a resource. Overall, having the right equipment is crucial for effective coin production.
thshen34
Hi,
What would be the approach to getting a good estimate of the amount of force needed to stamp an American quarter? (This is assuming you have the blank already made)
I'd like to get a good estimate, but more importantly an idea of what numbers go into this estimate, i.e yield strength, coefficient of friction, etc.
Thanks!
You're in luck:
http://www.ebay.com/itm/Columbia-360-Ton-Mint-Coining-Press-Coin-Stamping-Small-Parts-/270959333170
With a big enough press, you don't have to worry about yield strength, friction, etc.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
