Proving a/sinα=b/sinβ from Triangle Sides and Angles
  • Thread starter Thread starter Kamataat
    Angles Triangle
To prove that a/sinα = b/sinβ in a triangle with sides a, b, and c opposite angles α and β, the height h is drawn from the vertex opposite side c. Using the definitions of sine, it is established that b*sinα = h and a*sinβ = h. This leads to the conclusion that b*sinα = a*sinβ. Consequently, it follows that a/sinα = b/sinβ. The proof is confirmed as correct.
Kamataat
I have to prove that a/\sin\alpha =b/\sin\beta. A triangle has sides "a", "b", "c" and angles \alpha and \beta (opposite of the sides "a" and "b" respectively).
This is what I did:
Draw a line "h" as the height of the triangle on the side "c".
\sin\alpha = h/b. Multiplying by "b" gives b\sin\alpha = h
\sin\beta = h/a. Multiplying by "a" gives a\sin\beta = h
From this we see that b\sin\alpha = a\sin\beta and from this
\frac{a}{\sin\alpha}=\frac{b}{\sin\beta}.
Correct?
- Kamataata
Thanks for the quick help!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
