Dewar Flask: Clinging Noise Inside?
  • Thread starter Thread starter +energy
    flask
An old dewar flask, typically used for biological samples, is producing a strange clanging noise when shaken, leading to concerns about potential internal damage. The initial assumption is that a piece of glass may be rattling inside, possibly indicating a break or crack. Visual inspection reveals no obvious damage at the bottom, but there could be an issue at the top. To check if the flask still maintains a vacuum, one suggested method is to fill it with nitrogen or ice and observe how long it retains its properties. An additional recommendation is to use an inspection mirror, commonly found at auto parts stores, to examine the interior more closely. The conversation also includes light-hearted banter about the use of onomatopoeia in describing the noise.
+energy
I have an old dewar flask i found on clean up day, i was wondering, when i shake it, i hear a strange clinging noise inside, what could it be? (its the type used for bio samples)
Have you tried looking inside? My first thought is that it's broken, and a piece of glass is rattling around between the walls.
Also, I assume that you mean a clanging noise. Clinging is usually silent, with perhaps a moan or two. :-p
I can just see the bottom, where the sample holders go, there are no signs of break, but there could be a crack at the top somewhere. only way i can check it still has vacuum, is to fill it with n2 or ice and see how long it lasts?
Sorry about my onomatopoeia
Don't be; I can't make jokes without ammunition. :biggrin:
edit: Come to think of it, can you use an inspection mirror? That's a small mirror on the end of a telescoping handle similar to a an old portable radio antenna. You can get one for a couple of bucks at any auto parts supplier and most hardware stores. (They're used by mechanics to check in tight spaces and under things.)
I believe this happens when the scotch hardens into candy.
:smile:
Jeez, Flex! Long time, no giggles. From wherever you've been hiding, welcome back.
Just ONCE, I wanted to see a post titled Status Update that was not a blatant, annoying spam post by a new member. So here it is. Today was a good day here in Northern Wisconsin. Fall colors are here, no mosquitos, no deer flies, and mild temperature, so my morning run was unusually nice. Only two meetings today, and both went well. The deer that was road killed just down the road two weeks ago is now fully decomposed, so no more smell. Somebody has a spike buck skull for their...
