Constrained Lagrangian equetion (barbell)
  • Thread starter Thread starter Jengalex
    Lagrangian
The discussion centers on the dynamics of a barbell-shaped object using Lagrangian mechanics. The original Lagrangian included kinetic and potential energy terms, with a constraint defined by the distance between two points. The user derived equations of motion but encountered an inconsistency, suspecting an error in their approach. A response suggested that the degrees of freedom should be three instead of four due to the constraint, recommending a reformulation of the Lagrangian using three independent generalized coordinates. The user confirmed that this new approach resolved their issue.
Jengalex
Hi!
I tried to compute an ideal barbell-shaped object's dynamics, but my results were wrong.
My Langrangian is:
## L = \frac{m}{2} ( \dot{x_1}^2 + \dot{x_2}^2 + \dot{y_1}^2 + \dot{y_2}^2 ) - U( x_1 , y_1 ) - U ( x_2 , y_2 ) ##
And the constraint is:
## f = ( x_1 - x_2 )^2 + ( y_1 - y_2 )^2 - L^2 = 0 ##
I dervated L + λf by ## x_1, x_2, y_1, y_2 ## and λ:
## m \ddot x = - \frac{\partial U}{\partial x_1 } + \lambda ( x_1 - x_2 ) ## (1)
Four equtions similar to this and the constraint.
Then I expressed ## \ddot x_2 , \ddot y_1 , \ddot y_2 ## with ## \ddot x_1 , x_1 , x_2 , y_1 , y_2 ## and U's partial derivates' local values:
## m \ddot x_2 + \frac{\partial U}{\partial x_2} = - m \ddot x_1 - \frac{\partial U}{\partial x_1} ##
## m \ddot y_2 + \frac{\partial U}{\partial y_2} = - m \ddot y_1 - \frac{\partial U}{\partial y_1} ##
## ( m \ddot y_1 + \frac{\partial U}{\partial y_1} )(x_1 - x_2) = (- m \ddot x_1 - \frac{\partial U}{\partial x_1})(y_1 - y_2) ## (2)
After expressing ## (x_1 - x_2) , (y_1 - y_2) ## and ## \lambda ## from equation (1) and (2), substituted it into the constraint equation I got an equation like this:
## (m \ddot x_1 + \frac{\partial U}{\partial x_1} ) * <something> = 0 ##
I think it's wrong.
Can you confirm or point on my mistake?
Jengalex said:
Hi!
My Langrangian is:
## f = ( x_1 - x_2 )^2 + ( y_1 - y_2 )^2 - L^2 = 0 ##I dervated L + λf by ## x_1, x_2, y_1, y_2 ## and λ:
I think it's wrong.
I don't know what a "barbell-shaped dynamics" is, but if in your problem in the plane with two points there is a constraint, the degrees of freedom are 3, not 4, so I would have written the Lagrangian as function of 3 independent generalized coordinates, for example x1, y1 and the angle between the line connecting the two points (P1 = (x1,y1); P2 = (x2,y2)) and the x axis.
Yes I've tried it now, it looks fine. Thanks!
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
