Voltage difference of the wing of an airplane in Earth's magnetic fiel
The discussion centers on calculating the voltage difference across an airplane wing in Earth's magnetic field. Key equations mentioned include B=F/|q0|vsinθ and V=IR, with a focus on the conversion of gauss to tesla for accurate calculations. The velocity of the airplane is given as 223 m/s, and the magnetic field strength is noted as 0.50 gauss. Participants suggest that the equation V = vBL sin θ may be more applicable to the problem. Overall, the conversation emphasizes the need for precise unit conversions and relevant equations in solving the problem.
aChordate
B=F/|q0|vsinθ
V=IR
V=500m/h = 8.05m/h = 223m/s
L=35m
B=0.50gauss
0.50g=F/|q0|*223m/s*sin90
aChordate said:
B=F/|q0|vsinθ
Wouldn't V = vBL sin θ be more to the point?
I guess you mean v=500mph = 805kph = 223m/s
aChordate said:
B=F/|q0|vsinθ
V=IR
L=35m
B=0.50gauss
You need to change gauss to tesla.
Also, none of your proffered equations are directly relevant. Consider haruspex's suggestion.
