Solving Motion of Block A on Wedge B
The discussion revolves around solving the motion of block A on wedge B, both of mass m, with smooth surfaces. The user has derived equations related to the forces acting on the blocks but is struggling with the relationship between their accelerations and velocities. Key points include the need to apply the constraint that the blocks remain in contact, which affects their relative accelerations. A correction is noted regarding a dimensional error in the first equation presented. The conversation emphasizes the importance of understanding the dynamics of the system to find the displacement of block A after one second.
hav0c
A block A of mass m is placed over a wedge B of same mass m. Assuming all surface to be smooth. The displacement of block A is 1 sec if the system is released from rest is :
i have made fbds and have the relations-
1. ma1=(g-N1)/m
2.N1cos θ+mg cosθ=N2
3.ma2=sinθ(mg+N1)
now I am stuck
There is one more equation. The blocks stay in contact so their velocities perpendicular to the contact are same. What can you say about the relative acceleration perpendicular to the contact?
Likes 1 person
What velocities are the same?
I don't get it
EDIT:Thanks i got it A1=a2sintheta
1. ma1=(g-N1)/m
3.ma2=sinθ(mg+N1)
now I am stuck
Your first equation has a dimensional error.
I don't think the second equation would do any good. Your third equation is fine. Apply the constraint that blocks A and B stay together during the motion.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
