Operating Machine A with Machine B: A Technical Guide
  • Thread starter Thread starter ziimroze
    Machine
Operating machine A, which requires 3000 rpm and 10 Nm of torque, with machine B, a motor that provides 1500 rpm and 7 Nm, is not feasible without a more powerful motor. Gears cannot create energy; thus, they cannot compensate for the power deficit between the two machines. To operate machine A effectively, either a motor with higher specifications or a redesign of the system to adjust the torque and rpm is necessary. Using gears can increase rpm while reducing torque or vice versa, but losses will occur in the process. Ultimately, achieving the required performance will necessitate a motor capable of delivering the necessary power.
ziimroze
Dear Engineers,
Asslam u Alaikum(May peace be upon all of you)
I have machine A, rotates at 3000 rpm and required torque to rotate is 10 NM.
I want to operator this machine with an other machine B(motor) of 1500 rpm which can gives the torque of 7 NM max.
bc i m Electrical person and don't know much about this so I hv following questions
1. Can I operate it by using 2 gears,1 to shaft of machine A and 2nd to the shaft of machine B?
2. How can i calculate the gears size to meet the torque and rpm?
3. will the load of machine B increase in this case, even using gears? bc I don't want big difference in current.
regards
zafar
If machine A requires 3000rpm with a torque of 10Nm, it needs a power of 3000rpm*10Nm*2pi = 3.1kW.
Your motor can deliver a maximum of 1500rpm*7Nm*2pi = 1.1kW. Gears cannot produce energy out of nowhere - there is no way to operate machine A with your design values with motor B. You have to reduce revolution frequency or torque, or use a more powerful motor.
For an idealized motor, max torque occurs at zero rpm (stalled) and max rpm occurs with zero torque (no load). Maximum power occurs at 1/2 max rpm with 1/2 the max torque. As mentioned above, you need a more powerful motor.
thanks for your reply
So is there any way to increase rpm of machine A using gears on machine B, i. e. by increasing the torque of machine B and using a rather larger gears set, I mean what will happen if i use a motor A of 750 rpm which gives the torque of 14 NM.
Motor A, machine A? I am confused.
Gears can increase rpm and reduce torque, or reduce rpm and increase torque - always with some losses of course.
If your motor cannot deliver the given maximal torque value at the given rpm value, you also have to take into account the effect rcgldr mentioned.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
