Find Equivalent Capacitance for Circuit with Five Capacitors | Homework Question
  • Thread starter Thread starter fredrogers3
    Circuits
The discussion revolves around finding the equivalent capacitance between points a and c in a circuit with five capacitors and a battery. The values of the capacitors are given, and the user expresses confusion about the calculation process, particularly regarding the neglect of capacitor C5 in the equivalent capacitance formula. It is clarified that C5 can be disregarded because it does not influence the capacitance between points a and b due to the current's flow direction. However, it is noted that current direction typically does not affect equivalent capacitance unless nonlinear elements are present. The problem's wording may have contributed to the confusion regarding the calculation approach.
fredrogers3
A circuit is constructed with five capacitors and a battery as shown. The values for the capacitors are: C1 = C5 = 4.1 μF, C2 = 3 μF, C3 = 6.8 μF, and C4 = 3.4 μF. The battery voltage is V = 12 V.
Picture is here: http://s3.amazonaws.com/answer-board-image/7cae5cec-ff95-4f38-b803-29ac0b6ddae6.png
I need to find the equivalent capacitance between points a and c.
I have the answer but I am a bit confused as to how it is arrived at. See below.
I found the equivalent capacitance between a and b as c234=(c4)+(1/c23)
I see next that c234 is in series with c1 and c5. Why does the equation then become Cac=(1/((1/C1)+(1/C234)) and not (1/((1/C1)+(1/C5)+(1/C234))?
You can neglect c5 since it doesn't affect the capacitance at a or b since the current is flowing clockwise.
Apparently they're only looking for the capacitance to the right of the points a and c. This is not clear in your problem description, so perhaps the problem is stated differently in the original?
Likes 1 person
This was exactly the way the problem was written, so it left me a little confused as well
Current direction doesn't affect equivalent capacitance! Not unless there's a nonlinear circuit element like an open switch or a diode involved that would prevent "seeing" the capacitance.
