Determinant of a Finite Field 2x2 Matrix
rehcarlos
Find the determinant of:
|1 1|
|2 1|
The field is Z3.
The field is Z3, that is, to multiply two numbers, you first multiply then take the remainder of the division by 3.
I tried:
( 1 x 1 ) - ( 1 x 2 )
1 x 1 will be: 1x1 = 1 => then get the remainder of the division by 3 that is 1
1 x 2 will be: 1 x 2 = 2 => then get the remainder of the division by 3 that is 2
So, the determinant would be 1 - 2 = -1 => then get the remainder of the division by 3 that is -1
But the answer is 2
|1 1|
|2 1|
The field is Z3.
I tried:
But the answer is 2
In Z3, -1=2. Any two numbers that differ by a multiple of 3 have the same remainder when divided by 3.
I know it may be simple, but I'm still confuse,
-1 divided by 3 has a remainder of -1
2 divided by 3 has a remainder of 2
So I don't get how they have the same remainder
To say Z3 is about 'remainders' isn't quite accurate. Two number are equal in Z3 if they differ by a multiple of 3. That's the sense in which they have the same remainder. 2-(-1)=3*1.
Ok then,
Thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
