How Do You Write Position Vectors in Unit Vector Notation?
To write the position vectors in unit vector notation for a steel ball launched from a table, start by determining the x and y components based on the launch angle. For a launch angle of 30°, the x-component can be expressed as rx,30° = 30.0 cm * cos(30°) and the y-component as ry,30° = 0 cm + (30.0 cm * sin(30°)). Combine these components into the full position vector as r(30°)(t) = rx,30°i + ry,30°j. The confusion regarding the placement of zeros can be resolved by recognizing that the initial position is (0,0), allowing for expressions like 0i + 0j when necessary. Understanding this breakdown simplifies the process of writing the position vectors accurately.
Kieran Hughes
A steel ball is fired from a ballistic launcher at different angles. The launched ball has been found to travel from the edge of a table to land 30.0 cm from the far end of the table when starting from the height of the table and launched at an angle of 30.0◦ above the horizontal. When launched at 45.0◦ , the ball easily clears the table to land on the floor.
Letting the edge of the table from which the ball was launched have coordinates (x(0),y(0))=(0,0), write an expression for the x and y components of the object’s position vector. Next, write an expression for the full position vector.
I am trying to figure out how to write this expression. Underneath this explanation on my sheet I have a rx,30◦=x30◦=______, and a ry,30◦=y30◦=_______ and below that r(with -> on top)30◦(t)=______. I am confused as to write this, including the i-hats and j-hats unit vectors.
N/A
I understand the break down such as A = Ax + Ay = Axi + Ayj and so on, but where to put the numbers 0 and such are confusing me. I hope this format is correct for the forum!
First write the expression in x, then in y, then combine both using ##\hat{\imath}## and ##\hat{\jmath}##.
If you start with the individual components, you won't have to worry aobut the zeros. But you can also write a zero as ##0\hat{\imath} + 0\hat{\jmath}##.
