Potential of a dipole in E field
The discussion focuses on deriving the potential energy of a dipole in an electric field, specifically aiming to show that U = -p.E. The user attempts to start from the potential of two charges but encounters difficulties in transitioning from U = q(VB - VA) to the desired equation. The challenge arises from the differing distances in the potential terms and the absence of an acosθ term in their approximation. It is noted that the potential energy of the dipole's interaction with the external field varies with angle, while the interaction potential remains constant. The conversation highlights the importance of considering the external field's contribution to the potential energy.
raggle
I'm going over some EM notes and I found a derivation for the potential energy of a dipole in an E field which first found the torque on the dipole and then integrated.
I had a go at a derivation that goes the other way, starting from the potential of the 2 charges. I've ran into a bit of a problem midway through and I can't see how to get past it.
Want to show:
U = -p.E
U = q(VB-VA)
now I don't know how to get from here to what I want to show. Both of the potentials look like \frac{q}{4πε<sub>0</sub>r} , where the r is different in either potential.
The only thing I can think of is to use an approximation to r, but that doesn't give an acosθ term in the numerator.
Want to show:
U = -p.E
U = q(VB-VA)
now I don't know how to get from here to what I want to show. Both of the potentials look like \frac{q}{4πε_0 r} , where the r is different in either potential.
The charges of the dipole are in an external electric field. By changing the angle, that potential energy gained from the field changes, the potential energy of their interaction does not. You ignored the contribution of the external field to the potential energy.
As for the potential energy of the interaction between two point charges, it is \frac{q_1 q_2}{4 \pi \epsilon_0 r} where r is the distance between the charges.
ehild
