Electric field Phase change upon rarer to denser reflection of an EM
The discussion centers on the phase shift of electromagnetic (EM) waves when reflecting off different media, specifically the 180-degree phase change when reflecting from a denser medium to a rarer one. Participants seek an intuitive understanding of this phenomenon at the atomic or molecular level, rather than relying on classical analogies like strings. It is emphasized that the microscopic interactions between the electromagnetic field and matter are crucial to understanding these phase changes. Observations of wave properties can predict outcomes without needing to fully comprehend the underlying microscopic systems. The conversation highlights the importance of detailed analysis and experimental observation in grasping these fundamental wave properties.
ns_phonon
Can anyone please provide an intuitive explanation of why phase shift of 180 degrees occurs in the Electric Field of a EM wave,when reflected from an optically denser medium and also why the phase remains same on reflection from a denser to rarer medium?
please try to explain on an atomic/sub atomic/molecular level and "not by the classical example two strings of different materials"
I tried searching for it but, everywhere the result is just used.The reason behind it is never specified or if specified, it is either by using "Frensel equations and mathematics or as an analogy to two strings of different materials connected".
Please explain this phase change on a more microscopic level of interaction of electromagnetic field with matter rather than by an analogy of transverse waves in strings.
These are fundamental properties of waves. So the answer is that the microscopic system responds to the wave.
See http://www.acs.psu.edu/drussell/Demos/reflect/reflect.html for a wave-theory explanation (plus animations & questions to think about).
Note that it is not necessary to understand the microscopic system - you can observe wave properties experimentally - and then predict what will happen with confidence.
Are you familiar with the detailed microscopic analysis of electromagnetic waves impinging upon a dielectric?
Here is a complete lecture, from geometric, to waves, to electromagnetic waves ... with all of the details:
http://www.astro.phys.ethz.ch/spf/people/hanschmi/astobs/notes/files/astobs3.pdf
Likes 1 person
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
