What Is the Integral of Functions Like x^x, e^[x^2], and cos[x]^[sin[x]?
  • Thread starter Thread starter abia ubong
The integral of functions like x^x, e^[x^2], and cos[x]^[sin[x] cannot be expressed in terms of elementary functions. The integral of e^[x^2] can be related to special functions, specifically the error function with an imaginary argument. Attempts to simplify x^x using integration by parts lead to complex expressions that are not solvable. Overall, these integrals present significant challenges and do not yield straightforward solutions. The discussion highlights the complexity of integrating such functions in calculus.
abia ubong
i came acreoss a problem that's red like this ,wats the integral of x^x i gev it all i could so can anyone help me,furthermore wats the integral ,of a fuction raised 2 another e.g x^x,e^[x^2],cos[x]^[sin[x].and so on
One of them,viz.\int \mbox{exp} \left(x^{2}\right) \ dx,can be expressed as function of the "common" special functions (the erf of imaginary argument).The other that u mentioned cannot...
Daniel.
Where are you getting these problems? None of these functions can be integrated in terms of elementary functions.
Just a quick thought: what about breaking x^x into a product. For instance x^x = [x^(x-1)]*x^1 and then try integration by parts. It's been a while since my calculus days but that sounds like something I might have tried.
It's usless.Here's why.
\int x^{x} \ dx =\int x^{x-1} x \ dx=\frac{x^{x-1}x^{2}}{2}-\frac{1}{2}\int x^{x-1}\left[x(x-1)+x^{2}\ln x\right] \ dx
and the second integral looks horrible...
Daniel.
hey thnxs for all but they still do not help ,
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
