Integration by Parts: What's the Sign of that Last Term?
The integration by parts formula is expressed as ∫u dv = uv - ∫v du, indicating that the last term has a negative sign. This formula is derived from the product rule for differentiation, d(u * v) = u dv + v du. By integrating both sides and rearranging, the integration by parts formula is established. The discussion emphasizes the connection between differentiation and integration in this context. Understanding this relationship is crucial for correctly applying the integration by parts technique.
tandoorichicken
I forgot a little detail in the integration by parts formula
Is it \int u \,dv = uv + or - \int v \,du
I don't remember if its plus or minus...
Just remember that the integration by parts formula is deriviable from the formula for the product of a deriviatives.
d(u * v) = u * dv + v * du.
Now integrate both sides subtract int(v *du). Isn't math woinderful :-)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
