What Is the Acceleration of a Charged Sphere Fired Toward a Fixed Charge?
The discussion revolves around calculating the acceleration of a charged sphere moving towards a fixed charge. The initial attempt used the formula for acceleration based on Coulomb's law but encountered errors in integrating acceleration to find velocity. Participants suggested using the conservation of energy principle as a more appropriate method for determining the sphere's position when its speed is 20.0 m/s. This approach involves equating initial and final potential and kinetic energies to solve for the required variables. Ultimately, the conservation of energy method was confirmed as the correct approach to resolve the problem.
miniake
[SOLVED] Question about Electric field.
A point charge q_{1}=15.00\mu C is held fixed in space. From a horizontal distance of 3.00cm , a small sphere with mass 4.00*10^{-3}kg and charge q_{2}=+2.00\muC is fired toward the fixed charge with an initial speed of 38.0m/s . Gravity can be neglected.
What is the acceleration of the sphere at the instant when its speed is 20.0m/s ?
Express your answer with the appropriate units.
a = \frac{k*q_{1}*q_{2}}{m*r^{2}}
a = \frac{9*10^{9}*15*10^{-6}*2*10^{-6}}{4*10^{-3}*r^{2}}
a = 67.5 * \frac{1}{r^{2}}
By integration,
v = -67.5 * \frac{1}{r} + C
Initial conditions: v = 38 m/s, r = 0.03m
38 = -67.5 * \frac{1}{0.03} + C
C = 2288
v = -67.5 * \frac{1}{r} + 2288
When v = 20m/s,
20 = -67.5 * \frac{1}{r} + 2288
r = 0.029761904
a = 67.5 * \frac{1}{0.029761904^{2}}
a ≈ 76200 m/s^{2}
Since both charges are +ve,
a = -76200 m/s^{2}
However, the solution is not correct.
May anyone pointing out the errors? Thank you very much.
By integration,
C = 2288
When v = 20m/s,
r = 0.029761904
a ≈ 76200 m/s^{2}
a = -76200 m/s^{2}
Hi miniake, Welcome to Physics Forums.
I think the problem lies with your assumption that you can integrate the acceleration with respect to distance to yield velocity. Velocity is the integral of acceleration with respect to time.
Have you considered using a conservation of energy approach to find the separation for v = 20.0 m/s ?
Hello miniake
What is the correct answer ?
Edit :Conservation of energy is the correct way to approach the problem.
Thank you gneill.
It works, using the formula U_{1}+KE_{1} = U_{2}+KE_{2}.
Thanks again.
Tanya Sharma said:
Hello miniake
Using the above approach will work.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
