Manufacturing/Machining Companies
  • Thread starter Thread starter pyroknife
For manufacturing complex aluminum geometries, CNC machining is recommended, and contacting multiple machine shops for quotes is essential. It's advised to reach out to 6 to 8 local shops, considering a wider radius if necessary, and to evaluate not just pricing but also responsiveness and capabilities. Visiting top contenders and reviewing their past work can provide insight into their precision and quality. Proto Labs was mentioned as a reliable option with fast lead times, but the discussion seeks additional reputable companies in the U.S. Understanding the specifics of the project, including quantities and design complexity, is crucial for accurate quotes and recommendations.
pyroknife
Hello. I am looking to get some complex aluminum geometries manufactured. The mostly likely case is that these parts will have to be made on a CNC machine.
Does anyone have any recommended companies IN THE UNITED STATES that is pretty reliable in terms of lead time and pricing?
I can find a bunch of companies online, but I don't know who's good and who's not.
Likes Wallisprototyping
Hi pyroknife. I'd suggest contacting about 6 to 8 machine shops in your area and sending them your drawings for the parts and ask for quotes. Depending on where you're at, you may need to look up to a hundred miles or more away to get enough shops for quote. Give them quantities, but if you're not sure how many you need, put 2 or 3 values down from a low figure to a high figure and cover a range.
When they get back to you, don't just look at cost, look at their responsiveness and go visit one or two of the top ones. Ask for examples of parts they've made that are similar to yours. Look at the machines they have to see if they appear to be the right kind of machines to make the parts with the precision you're looking for. Come up with a list of questions for them and consider spending an hour or so at the shop. If you have little experience with how things are manufactured, talk to them about it and see if they can make any recommendations on how to improve the design for manufacturability. But think about what you want to do and what you want to see. Might want to bring someone else along as well, just because 2 heads are better.
Hi. Thanks for the reply. I have called up some local companies, the majority of them are booked, so I thought I'd try some non-local ones.
I got a quote from a big company called "proto labs." They have very fast lead times and considered a pretty big company. I was just wondering if there were any others like these, big, well-reputed companies.
pyroknife said:
Hello. I am looking to get some complex aluminum geometries manufactured. ...
In what quantity? Do you need just one batch of parts? Is the design a single piece, or multiple pieces requiring assembly? What is the general size of each piece (10 mm3, 500 mm3?)
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
