Finding Equation for Linearly Changing Density
  • Thread starter Thread starter rmfw
    Density Linearly
To find the kinetic energy of a bar with linearly changing density, the equation for density (λ) must be established, typically in the form λ = kx. The center of mass is located at 2b, and the challenge arises when attempting to integrate the density over the specified limits, leading to a false statement regarding mass distribution. It is clarified that the assumption of equal mass distribution on either side of the center of mass is incorrect. The discussion emphasizes the need to accurately define the total mass in terms of the variable density to resolve the problem. Understanding the relationship between linear density and center of mass is crucial for progressing in the calculations.
rmfw
I need to find the Kinetic energy of a bar rotating about its center of mass.
I know the bar as length 3b and it's center of mass is located at 2b, the bar density changes linearly along it's length.
T=1/2 W^2 I
So I was trying to find I for this setup, which requires me to find the equation for density (λ).
I know the density changes linearly along it's length so it must be similar to an equation of the type: λ = k x , with k being a constant and x being position.
Now to find k I did the following equations:
∫λ dx = ∫ k x dx = m/2 (limits of integration are from 0 to 2b)
∫λ dx = ∫ k x dx = m/2 (limits of integration are from 2b to 3b)
The problem is that I get a false statement this way, making it impossible to find the equation for density.
This is very basic stuff but it's giving me a headache since I need to move forward on the problem but I can't due to this niche, help? thanks
In general, it is not true that half the mass will be on one side of the CM and the other half on the other side of the CM.
See here, near the bottom of the page, for finding the CM of a continuous distribution.
Note, "varying linearly" could be interpreted more generally as saying that ##λ = a + kx## where ##a## is some constant. But, you should be able to use the integral formula for ##x_{cm}## and the fact that ##x_{cm} = 2b## to show ##a = 0##.
Likes 1 person
What is your general equation for the center of mass if the linear density λ(x) varies with with x? First state your equation for the total mass in terms of λ(x).
Chet
