Would this high speed flywheel concept work?
The discussion centers on the design of a high-speed flywheel, focusing on the challenges posed by centrifugal forces that could cause structural failure. The proposal involves using interference fit tubing that applies crushing forces on the flywheel as it cools, potentially counteracting centrifugal forces. However, concerns are raised about whether these outer tubes would instead create tension that could weaken the flywheel's surface. The need for a stronger material, such as titanium around a steel core, is suggested to enhance structural integrity. Additionally, the importance of conducting a proper stress analysis and considering the distribution of mass for optimal performance is emphasized.
Webbd050
Im working on designing a high speed flywheel as part of a project. The main issue is the centrifugal forces acting on the flywheel to tear it apart. If i was to construct a flywheel using interference fit tubing which is put together using thermal expansion of the outer tubes so that they are effectively crushing the flywheel when they cool, would these crushing forces oppose the centrifugal forces thereby allowing the flywheel to spin faster without breaking? Or would the outer tubes be under tension and experince a force from the inner core outwards which would assist the centrifugal forces making the flywheel weaker near the surface where there is the greatest inertia? If any of that made any sense to you do you think it would work? Would it need a stronger material to provide the crushing force? Such as a titanium tube around a steel core? I know they use carbon fibre wraps around flywheels in Kers systems is that the same principle? Thanks.
Check out the "Related Discussions" thread links at the bottom of this page. Some of those discussions should help you think more about your question. Consider also that slight imbalances in the flywheel generate very high forces that tend to disrupt _______ :smile:
You need to do a proper stress analysis on the design. To store kinetic energy, you want most of the the mass at a large radius. On the other hand for maximum strength, most of the material is at a smaller radius to resist the force from the outer rim. For example look at the different shapes of rotating disks in a jet engine (find cross-section images on Google), depending on the RPM, radius, and the amount of radial load on the rim from the different sizes of the blades.
If you produce a radial compressive stress in part of the structure, you will probably also create a circumferential tensile stress somewhere else. The question is whether the tradeoff between the two is beneficial or not.
Some of the students at my uni (many years ago) were working on a flywheel-driven light vehicle design. The project was abandoned when they realized it was in danger of flipping over sideways if it tried to go up a steep incline. :smile:
Could two opposing flywheels overcome gyroscopic problems?
Sure. But the equal and opposite forces are still acting on the bearings of the two flywheels, so the bearing supports need to be designed to withstand with that.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
