Question concerning the direction of the vector r in the FL
  • Thread starter Thread starter 3102
    Direction Vector
The discussion focuses on the direction of the vector r in the Feynman Lectures of Physics, specifically in Chapter 13.3. The original question seeks clarification on whether vector r in equation 13.5 points from mass mj to mass mi. Participants confirm that the convention illustrated in figure 13.2 indicates vectors point from 1 to 2, and there is a suggestion that the vector should be consistent across equations 13.15 and 13.16. Overall, the consensus is that the vector direction should align with the established conventions in the text.
3102
Hello! I've got a question concerning the direction of the vector r in the Feynman Lectures of Physics in Chapter 13.3 http://www.feynmanlectures.caltech.edu/I_13.html#Ch13-S3
Which direction does the vector r in equation 13.5 point in?
The long equation before equation 13.6 suggests that it should point from ##m_{j}## to ##m_{i}##.
Is that correct?
The convention is given in figure 13.2: the vectors point from 1 to 2.
Do you mean 13.15 and 13.16?
The vector should be the same in both equations.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
