Heat Energy & Mass: How Can Snow Have More Heat Energy?
The discussion centers on the comparison of heat energy between 30,000 kg of snow at 0°C and 1 mL of water at 100°C. It emphasizes that snow at 0°C contains more heat energy than snow at lower temperatures, as heat content is measured on an absolute scale starting from absolute zero (-273°C). The calculations demonstrate that when heating both samples, the large mass of snow (sample A) results in a significantly higher total heat energy compared to the small volume of water (sample B). Specifically, sample A yields approximately 9.788 x 10^5 kJ, while sample B only reaches about 0.07562 kJ. This illustrates that despite the higher temperature of the water, the sheer mass of the snow contributes to its greater heat energy.
NoHeart
how can 30,000 kg of snow at 0 C have more heat energy than 1 mL of water at 100 C?
Science news on Phys.org
Snow at 0C still contains heat - more heat than snow at -5C. Heat content is measured on an absolute scale starting at absolute zero (-273C).
Keep in mind that when measuring heat content, temperature must be measured on the Kelvin scale.
Suppose we have a sample A of 30000 kg of ice and a sample B of 1g of ice(1ml of water) both at absolute zero, then if we start heating them, so that sample A reaches 0^{0}\ C and sample B reaches 100^{0}\ C, we can calculate the heat they will have,
\mbox{For Ice at sample A,}
M_{ice}\ S_{ice}\ (\delta T)\\ =\ 30000\times 1000 g\ (0.50 \frac{cal}{g K})\ (273.15\ K)
= 4097250000\ cal
= 9.788 \times 10^{5} kJ
\mbox{And for ice(water) at sample B,}
M_{ice B}\ S_{ice}\ (\delta T_{1})\ +\ M_{ice B}\ L_{fusion}\ +\ M_{water}\ S_{water}\ (\delta T_{2})
=\ 1g\ (0.50 \frac{cal}{g K})\ (273.15\ K)\ +\ 1 g\ (80\frac{cal}{g})\ +\ 1\ g\ (1\frac{cal}{g K})\ (100 K)
=\ 316.575 cal
=\ 7.562 10^{-2}\ kJ
So u can see, that the sample A of ice has much much more heat! :approve:
