Fuids - vorticity from viscocity
  • Thread starter Thread starter julian
    Vorticity
Inviscid flow that begins with no vorticity will not produce vorticity, as only viscous shear forces can induce rotary motion. The Navier-Stokes equations support this, showing that if the flow is initially irrotational, it remains so over time. In two-dimensional flow, the vorticity transport equation simplifies, confirming that vorticity remains zero if it starts at zero. While the theoretical framework suggests no vorticity production without initial presence, real-world scenarios often violate this due to conditions like the no-slip condition at solid boundaries. Ultimately, vorticity can emerge from various phenomena, but the no-slip condition is a primary factor in its generation.
julian
If invisid flow starts with no vorticity then no vorticity will be produced. This can be understood
intuitively: we note that of the three types of force that can act on a cubic fluid
element, the pressure, body forces, and viscous forces, only the viscous shear forces are
able to give rotary motion. Hence if the viscous effects are nonexistent, vorticity cannot
be introduced.
Can this be derived from the Navier-Stokes equations for vorticity:
\dfrac{\partial \vec{\omega}}{\partial t} + \vec{u} \cdot \nabla \vec{\omega} = \vec{\omega} \cdot \nabla \vec{u} + \nu \nabla^2 \vec{\omega}
\nabla \cdot \vec{u} = 0?
Sure. Note that the vorticity transport equation can be rewritten with the material derivative instead
\dfrac{\partial \vec{\omega}}{\partial t} + \vec{u}\cdot\nabla\vec{\omega} = \dfrac{D\vec{\omega}}{Dt} = \vec{\omega}\cdot\nabla\vec{u} + \nu\nabla^2\vec{\omega}.
For an inviscid flow, that last term is zero (or neglected), that leaves
\dfrac{D\vec{\omega}}{Dt} = \vec{\omega}\cdot\nabla\vec{u}.
So basically, this states that if the flow is irrotational initially, then ##\vec{\omega}(t=0) = 0##, and therefore
\dfrac{D\vec{\omega}}{Dt} = 0,
meaning the flow remains irrotational forever. That does leave open the possibility that if the flow initially contains some vorticity, the vorticity can change over time and space.
If you want to take that further, consider a 2-D flow, in which case the ##\vec{\omega}\cdot\nabla\vec{u}## term drops out as well (it only only contains derivatives in the direction that is zero by the 2-D definition) and
\dfrac{D\vec{\omega}}{Dt} \equiv 0
regardless of initial conditions.
This whole concept is known as Kelvin's theorem.
Thanks for that. I also want to know if you start with no vorticity at an instant in time, will the presence of the viscous term lead to the production of vorticity?
In 2D the vorticity equation is just the diffusion equation for the vorticity, and from what I know about that I would say that if there was no vorticity to start with there would be no production of vorticity.
Can vorticity only be produced from the non-slip condition for solid objects?
Apologies for the late response; it's been a busy weekend.
Anyway, in theory, according to the vorticity transport equation, if you start with no vorticity you should never have any. However, this simply can't happen in most real flows subject to, as you said, the no-slip condition except in a few instances (e.g. Couette flow). Vorticity can also be "produced" through phenomena like free shear layers, but the no-slip condition is the big one.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
