Solving Transistor in Cutoff: Vtp=-0.4V
  • Thread starter Thread starter carnot cycle
    Transistor
The discussion centers on determining the operational region of a p-channel transistor with a threshold voltage (Vtp) of -0.4V. The gate-source voltage (Vsg) is 0V, leading to confusion about whether the transistor is in saturation or cutoff. Despite calculating the saturation voltage as -0.4V and observing that the source is at 2.2V while the drain is grounded, the consensus is that the transistor is in cutoff due to Vsg being less than Vtp. Clarification is provided that for a p-channel MOSFET, cutoff occurs when Vsg is less than the threshold voltage. Understanding these relationships is crucial for accurately analyzing transistor behavior.
carnot cycle
The threshold voltage (Vtp) of this p-channel transistor is -0.4V. Determine the region of operation of this transistor.
Vsg + Vtp = Vsd(sat)
Since the gate-source voltage is 0V, and the threshold voltage is -0.4V, the saturation voltage should be -0.4V. The source is at 2.2V, and the drain terminal is connected to ground potential. Because this Vsd is greater than the saturation voltage that I found using the above equation, I thought this transistor was in saturation mode. However, the book's answer says that the transistor is in cutoff because the gate-source voltage is zero.
I thought that if the gate-source voltage (0V) is greater than the threshold voltage (-0.4V), the transistor could not be in cutoff.
Any help would be greatly appreciated. This seems like a very easy problem, but I have just started studying transistors so I am still trying to conceptually grasp them.
Define Vsg as Vs - Vg. Then a p channel MOSFET is always in cutoff when Vsg < Vt where I define Vt to always be positive. Look again at your equations for cutoff, saturation and linear modes.
